Want Extended Radius Arms For 2" Lift
trailblazr81
Hey guys Im looking at getting another Ranger. A 2 wheel drive 1995 ext. cab. Its gonna split DD duties and I dont want to lift more than a couple inches, and want to know what extended radius arms I can use. The ones Ive found are either for 4wd trucks or are 2wd but for 4-6 inch lifts, like the Skyjackers. It will only see mild off road use but I'd like the benefits of longer beams over stock or stock with drop bracket. Can I use beams for 4" lift? Are the 4x4 beams different than the 2wd?
Thanks!
From what i understand, there'd be no point in longer arms for such a short lift. Although if you insist, you could make them yourself.
