v-8 conversion fuel help
Ok Thank you , looks pretty nice I think all I have to do is 90 the tank side and then a straight fitting onto fuel filter side.. I never worked with that but looks like it would be perfect my only thought is the fuel pump assembly had the 3/8 side of the fitting hooked to the original filter that was 3/8 on the end closet to the tank and then 5/16 on other side of filter going to fuel rail so when I put the new filter on I used it the same way 3/8 side from the tank the engine side was 5/16 so I just used the original lines the same way clicked them on and ran a 5/16 fuel hose from filter to tank both 5/16 with clamps to ,make sure it worked and it dropped the pressure to 55 lbs approx so hopefully this is correct I would like to use the 5/16 as the fuel pump assembly and the filter are the same size It would be a much safer and cleaner way to run return line back to tank .. The filter I am using is from a 2000 ford ranger 4.0 or mazda 4.0 that I bought on amazon .. Thanks again , Bill
