- Aug 11, 2007
- Age
- 69
- Ontario, Canada
- Automatic
- My credo
- Love Thy Neighbor
Updated January 2018: Here it has been almost five years since I originally posted this and between Photobucket carping out and the whole thing being a monumental failure some may be wondering why I didn't just delete the post...
Good ideas are posted by other members with photos that still work and most of their links are working...I didn't go through every line and check them but I can do that soon...just wanted to add why the post is still visible...other than my ego and seeing my name up in lights...but I'd rather it be for something that works than a fiasco that nearly bankrupted me...lol
Anyway...my links still work...some of them...but because of the problems I had and the ease of use the other ideas from other members provide I will simply remove the links to my images...
My apologies if this turns out to be a waste of your time but I did have good intentions...to try to keep a dying engine going longer than it should have lasted and, to be honest, it made it almost two years before I had to scrap the whole project and trade up to a 2.5 mounted on a 96 rolling frame...all I had to do was mount the body and box and rewire the 88 cab with the 96 harness and dash...now that was a project worth documenting...and I might do that some day too...
Updated June 2, 2013.
Original Poster: Mark_88
Difficulty: 1 out of 10
Time to install: About 30 minutes
Disclaimer: The Ranger Station.com, The Ranger Station.com Staff, nor the original poster are responsible for you doing this modification to your vehicle. By doing this modification and following this how-to you, the installer, take full responsibility if anything is damaged or messed up. If you have questions, feel free to PM the original poster or ask in the appropriate section of The Ranger Station.com forums.
Brief Explanation:
On carbureted 2.0 and 2.3 engines there is a vent pipe from the Valve Cover (VC) or oil filler cap that goes into the breather. With a bit of excess pressure in the engine this can lead to oil or foam pooling in the breather which is both messy and generally destroys a good air filter. The crankcase pressure can also force the oil out and cause a severe oil loss situation as well as allowing the oil to be drawn up through the PCV and into the combustion chambers resulting in oily smoke that is generally frowned upon by emission laws and other motorists.
In my updated version, both the Valve Cover (VC) and crankcase through the PCV have been routed to the catch can.
Brief Explanation:
