Two starter questions
josh_m
1. How does my starter solenoid get wired ? As in which wires go where..
2. How can i bypass my clutch safety switch
Large post on relay gets the positive cable from the battery cable, and two red wires with fuse links, one green, the other brown which connects to yellow wire.
Connect another cable from the other post on the starter relay and connect to the starter. No other wire goes on this post.
The small red/lt grn wire goes to the small terminal on the center of the relay. This wire comes from the ignition switch to energize the relay.
Find the red/lt blu wire on the clutch interlock switch. (There may be two red/lt blu wires. If so, connect them together.) If there is only one red/lt blu wire, and a red/lt grn wire, connect these two wires together. (The red/lt grn wire is shown to be on the trucks equipped with the 2.0 engine, but check to make sure).:)shady
