corerftech
Tried to flip and play with the cast logs. One is ideal. If you take driver side downward dumping and move to passenger, it dumps perfectly in front of the mount but immediately behind the FEAD bracket. Piped down and towards the driver side its great.
The issue is the passenger to driver move, worth less. The steering box is smack in the way. If I could move the steering box to the far side of fram rail, it woudl be stellar...
Flipping driver simply upside down WORKS, but a sparkplug boot WILL DIE for sure and the header touches with significant interference the entire length of the head. Unless I cut away material...... and I cant, they arent thick enough walled...... so thats out.
The steering box is pissing me off. Else Id have a solution and it would be great.
Has anyone seen a steering box moved? Changed?
The steering shaft from firewall toes toward the engine (not straight), if a box was on other side of frame rail, it would have to climb over the frame rail to meet the box..... or so it seems.
Anyone put a pinto front end on a ranger??? Down the rabbit hole I descend.......... save a buck on a turbo with cast iron headers, invest $30k in a front end.......
I thought maybe Id buy some stubbed flanges, the headers wont look real pretty but I do pie cuts pretty well and might be able to make a pair with just some (about 50) pie cuts cut from a good length of pipe. More time than budget....
Or move the steering box.....whichever is cheaper, more expedient, frees up more space.
