Twin piston swap
stegomon
auburn/minot maine
Can I use a spinal and rotors from a 91 dana 35 onto the twin piston steering knuckles from a 97 dana 35?
There may be differences if you want ABS but if you don't care about ABS they swap. You will have to remove the sensors if the knuckles had front ABS and your other parts didn't.
It is going on my 88 B2 dana 35 swap. I want the twin piston calipers. I have a new set of rotors bearings on my current set up.
Original ABS spindles are notched to clear the ABS sensor. Non ABS spindles are not notched. If you knuckles have ABS sensors just remove them and you are GTG either way.
Spindle should be ok, but aren't the rotors different? I know rockauto has a listing for 95-97 only.
