Turn signals died, thoughts?
triumphrider-1
Port Huron, MI
As the title states, my turnsignals stopped working yesterday. Everything else works fine, and the fuses are still good.
At this moment I'm thinking that the multi-function switch took a crap (atleast the turn signal part of it), what are your guys thoughts / opinions on it?
Thanks
DO you parking lights still work? Maybe your flasher is shot.
I would start with the flasher first. Do the emergency flashers work?
As stated, everything else works; the parking lights and hazards were the first things I checked.
Something I did forget to mention earlier, the indicators on the dash do not work when I select the turn signals either (probably just because of the circuit dead, but maybe not).
Fixed.
Apparently I'm blind, because I missed the blown fuse last time I checked...either that or I can't read. :icon_twisted: So a new fuse is in and all is good once again.
Thanks for the help fellas. :icon_thumby:
CHECK FOR a burnt bulb on most vehicles when a buld burns out, it either flashes real fast or stops altogether.
Indeed. However, none of mine were working, but all were working with the hazards, where they were fine the previous day.
