Turn key and nothing
TLBNut
5+ Year Member
Clarksville, TN
Ok, I just bought a 1993 Ranger 2.3L 5 spd, it will not start. If you turn the key, power comes on but no start. I can start it if I turn key on and use a jumper wire from the positive post to the "S" terminal on the solenoid. I have replaced the following items, one at a time and no change. The Battery, clutch sensor switch, Battery cables, solenoid, Key lock cylinder and ignition switch. I am stumped. If I am not mistaken the only thing left in that system is the Ignition Control Module? That is a pricey part, so I want to be sure.
Thank you,
Did you check the clutch switch?
Ah yes I knew I forgot something in the post, yes I did replace the clutch sensor switch.
maybe the Bendix in the starter us stuck out.???? just throwing that out there :icon_confused:
When it starts with the jumper wire does the engine sound normal ( do you hear the bendex spinning constantly while truck idles ? ). p.s. did you get my p.m. about other parts ?. also my Rangers are 5 speeds, I may have used parts you can try ( mine are 4.0l ) not sure what all crosses over. Also I have the factory Ranger repair books, Contact me if you want to use them.
1992 START circuit is pretty simple with manual trans
When you turn the key to START a Red/light blue stripe wire sends 12v from ignition switch(under steering column) to clutch switch(on clutch pedal pushrod)
Next to this red/light blue wire on the clutch switch is a Pink wire
These two wires are usually #5 and #6 on the 6 wire clutch switch connector
The Pink wire runs thru the firewall and becomes a red/light blue wire that runs to the "S" post on the starter relay(solenoid)
Battery-------ignition switch-----(red/blue)-------clutch switch-----(pink)-----firewall----(red/blue)----starter relay
I would start at clutch switch, make sure you are getting 12v on red/blue wire when key is in START
You can jumper red/blue and pink wire together to see if START now works, if it does then new clutch switch is bad or not closing like it should with pedal all the way down
I just replaced the Ignition Lock Cylinder on my '92 Ranger, and now my truck isn't wanting to start. it's acting like it's a low battery. but when i just turn the key on, the radio will come on (if i turn it on), the fan will blow, and all that, but it's not even wanting to try to crank. Everything is hooked up like it was when i took it off. is there something that i'm missing?
when my friend gets up, i'll see if i can jump it.
Make sure you got the cylinder in properly. The cylinder pushes a rod that moves down the steering column and actuates the switch. It sounds like it isn't pushing the rod far enough to push the switch to the start position.
it's all the way in. i can turn the key back to take it out, and i can turn it to try to start it, but when i do, i get nothing
Why did you replace the key cylinder?
As said the key turning pushes and pulls an actuator rod inside the steering column and that rod Slides the ignition switch, under the steering column, into its 4 positions, ACC, OFF, RUN, START
There is also a safety switch to prevent starting "in gear"
With a Manual transmission the switch is on the clutch pedal's push rod, clutch pedal must be all the way down to CLOSE the switch
When switch is closed then starter motor can be activated using the key
i replaced it because out of the blue, the one i took out just suddenly stopped turning yesterday morning when i was getting in it to take my girl to school, and myself to work. i even took a pair of pliers to try to turn it, while not applying TOO much pressure as to break it or bend the key out of whack. but now after i replaced it, the key turns, but the truck won't start. there's no anti-theft, and the key's not chipped.
That could be because the actuator rod or ignition switch was damaged, so stuck key was just a symptom not the problem
I would pull out the ignition switch and see if you can manually move it into its 4 positions
Its just above brake pedal area on bottom side of steering column
Unhook 1 battery cable when removing the switch
Its often easier to drop the column down to do this, read here: https://www.therangerstation.com/fo...replace-ignition-switch-on-1992-ranger.74596/
well, i just got the column dropped, the switch pulled, and i am able to move it to all 4 different positions. the actuator arm is still attached, and it does work.
i assume that while i was tapping the screwdriver into the ignition lock cylinder, the actuator rod must have come out of its slot from the ignition switch. but when i got the switch back on, i made sure that the rod was in its slot, put the ignition lock cylinder in, with the column still dropped, and i reconnected the battery. i tried to start it, and sure enough, it fired right up. so i ended up sinching everything up, and put it back together.
