Truxxx Level Kit Discount
Do you have all the tools you need? If not, I can look to see what I have. Like the sockets for the half shaft nuts as an example. I have a kit.
I’m pretty sure I do. Someone on 5G told me the hub nut has to be torqued to 220 ft/lb so I’ll have to see if mine goes that high. I’d prefer not to have to take it off though. 466 Ohio Ave. Rochester.
Redline D6 for the transfer case arrived today.
As of right now I have no plans, but I’ll be home. Not sure about transportation
Bring your kit just in case.
I’ll have to double check but I’m pretty sure I have the torque wrench you need. I rarely ever use it because it’s such a monster. I believe I specifically got it for situations like the axle nuts with high torque values.
Thanks. This guy seems to pull it down pretty far without undoing the hub nut.
Thank you for sharing this information. Can you tell me where I can get a discount code? I'm looking to buy some parts for my car but don't know where to get the codes. Can you show me where to get the discount code.
Should pop up when you go to www.truxxx.com.
As I recall the code was Truxxx40.
