True or false
Ozwynn
If you didn’t bleed for it you don’t deserve it
Berrien Springs, MI
MI - USA
If you can't go through it or around it, then go over it.
True or false
Whe. Your transmission cooler splits and is leaking green coolant into the transmission it will give the ATF a slight orangish tint
Trans cooler in the rad is the only place coolant and atf can meet. The other way water can get it is of course too deep of water driving through it.
It will likely make the trans fluid look something like a strawberry shake, but orangeish is also a valid color. Especially in the North West where they make the companies put the bittering agent in the coolant.
