- Jan 14, 2024
- Gdl, Mexico
- 2.3 (4 Cylinder)
- Manual
Hi, everyone.
My truck is a 2.3 L 1988.
I changed the gas pump inside the tank and the gas filter; I also sealed a leakage in the small reservoir between the filter and the gas pump on the chassis. now the truck is not starting.
It does crank but that's all. I tried putting some starting fluid but it is still not working. (I added some videos so you can see what I did)
I tested the ECC and the Gas pump relays and they are both working well.
Next, I took the plugs and cranked the truck and the plugs had spark, though I thought it was not quite strong.
Video:
www.youtube.com
Then I checked the plugs and the sparking plug wires, those are the results:
1 cylinder.
Wire:
10,4 k ohms
34 inches long
Plug: 6,65 k ohms
2 cylinder.
Wire:
9,3 k ohms
30 inches long
Plug: 6,56 k ohms
3 Cylinder
Wire:
9,31 k ohms
30 inches long
Plug: 6,31 k ohms
4 Cylinder
Wire:
9,9 k ohms
34 inches
Plug: 8,5 k ohms
I think they might be good enough.
Next thing I did was checking the fuel pressure on the test port on the fuel rail. I took it off and turned on the pump, there was gas though I'm not sure it has pressure enough.
Video:
youtube.com
Any help will be highly appreciated.[/MEDIA]
Video:
- YouTube
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
1 cylinder.
Wire:
10,4 k ohms
34 inches long
Plug: 6,65 k ohms
2 cylinder.
Wire:
9,3 k ohms
30 inches long
Plug: 6,56 k ohms
3 Cylinder
Wire:
9,31 k ohms
30 inches long
Plug: 6,31 k ohms
4 Cylinder
Wire:
9,9 k ohms
34 inches
Plug: 8,5 k ohms
Video:
- YouTube
