- Jan 16, 2009
- Decatur, IL
- Automatic
I can't help you with the passenger side locking hub, as I have a 4x2, but if your gas gauge doesn't work, there's a good chance you have a bad fuel sending unit. Unfortunately, you would have to drain your gas tank and then drop the tank to get access to it, as it is usually right next to, if not part of, your fuel pump. I would talk to your uncle first, though, as he is the Ford guru, as you stated earlier. Like I said, I am not a mechanic, so with ANYTHING I say, I would get a second opinion. Or more, perhaps, depending on the situation. At least you got her running! That's always a step in the right direction. Cheers!
