bolting it through the bed is the best option as it won't go flying during an accident and it will not get stolen. if you need to be able to remove it from time to time, you can always use wing nuts inside the box to get it off more easily. just check them frequently to make sure they stay tight. just my $.02.
i put a small box in my ranger. i ran a thick cable under the bed liner and drilled holes in each side to the liner then just lock the handles on each of the box to the lopped cable. i can take it off and put it back on in less than a minute.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
