TRS-3 20th Anniversary Ford Ranger
I've got 3 BII's that I'd let you have your pick from. Spare 2.9 engine too.
GB :)
Curiosity is getting the better of me. Are any of them solid? What kind of shape are they in??
Also, do you have a thread on here showing your Ranger? I was looking, but couldn't find one. Likes pretty nice in your avatar.
The 89 or 90 model is the best one as far as the body goes, but I removed one rear leaf spring shackle and maybe the frame bracket. I can't remember. It does need a new grille and other front end stuff. Both fenders are good if memory serves me, as well as the hood. I think it was only the grille and headlights that suffered. Small deer incident. It would make a very nice BII when put back together. The interior was really nice and the paint/body is in great shape. Engine and trans have been removed.
The 88 was burnt under the hood. It's garbage except for the chassis and suspension/axles. I bought it for the trans. Engine is garbage.
The other 89-ish Bronco is rusty. Trans was out and I bought it because it ran so good. For a spare engine..
89 Ranger single cab long bed 2.9 5spd manual transfer case needs love. Needs a cheap paint job. I cut the rear wheel wheels larger to remove the cancer and fit larger tires. Never got around to the front.. Runs but has another cracked head. It's cracked like 5 heads on two different blocks, including a Jasper rebuilt. Everything works on it though.
I've got a blown up 2002 4.0 extended cab 5spd too.
The mice are slowly getting to all of them though.
As for my trucks, I don't have any build threads on them anywhere.
GB :)
2500?!?!?!
are you close enough to look at it.??
shit....i want it
Stock motor and transmission for reliability.
hmmm. not sure that would meet reliability reliably.
We need to have a private negotiation about that D35 and 8.8 you have ;)
if they are usable....they are yours...
no negotiating necessary.
I keep looking at that Bronco II for $2500. I'd still need to locate a 4 inch lift and some extended radius arms. I'd use cut out fender flares to fit 33's.
I'm starting to feel like Hanible Smith from the A-Team.
I'm probably more of a Murdock.
is bobby Mr. T?
