trouble unhooking rad arms
its kinda hard when you have to work in a positino like i am, if i get my moms camera tomorrow ill get a pic of my work area
Tell me again why you are taking apart a nice looking, running, classic Bronco to do a SAS on a rusted out Ranger.
hhahahaha
sorry but shooting flames out the carberatour while tempting to start and failing, leaking oil in every spot possible, literally rusted in half, literally no chassis support members, doesnt qualify as running and nice looking
Get an airchisel. I used one with a dull flat tip to hammer away at the EGR nut on the exhaust side in my bros 92 crown vic, them things have absolutey no room to work but the air hammer did it. Use it to hammer on the wrench if you have an air tank, (chisel 30 bux at advance)
DAMN, You didnt seriosuly quote dusty did you LOL
ook i know what an air chisel is now, my budy has one but i dont see how that will work with my problem? just chisel on the bolt to get the rust off?
You can chisel against the bolt to try and turn it, or put the chisel against your wrench like a hammer but using less space to swing.
****Don't try to chisel, break, the bolt off. Plase the flat end against a corner of the bolt and attempt to loosen it. In other words chisel it counterclockwise.
wont the chisel just slip off the wrench?
It might, I also had a flat blade with a v notch that I used on wrenches.
that sounds more like it, or i could just take the grinder to make a notch in it
are those air chisels expensive?
Advance autoparts when it was discount had them for around 30 bucks I think. Or was it 60. Either way, I spent money I didnt have at the time. But it saved my life. I even found the cam lock tools and a mechanic to let me borrowthem, but I still wouldnt have got the job done if I hadnt found a method for beating that egr nut.
do like people have said, breaker bar, pb blast,torch,air chisel etc.
just be careful not to give yourself a hernia:icon_surprised:.....see it happen, i bet its real painful......:shok:
hhahahaha
Oh ok. I must have missed that part somewhere. I just saw some pics that made it look pretty decent.
oh yea she does look pretty good on the outside, but ill try to get some pics for ya later
