Transmission interchange
vbrad511
Springfield, Illinois
I've got a '97 Ranger, 4.0, 5 speed, 4wd, with roughly 320k on it. I have a line on a spare transmission, but out of an '04, 4.0, 4wd. Will it work for me? Is it any sort of upgrade?
It'll work for you. The internals are not quite the same but if you're just swapping one out with another one then that's a moot point. It's not really an upgrade (although it does have HD in the part number.)
IIRC if you have a manual t-case the newer transmissions aren't drilled & tapped for the shifter linkage.
Will the gear ratios be the same? Will the speedometer be accurate?
