- Jun 1, 2001
- Age
- 64
- 1987... sorta
Let me clear something up, the last duraspark Rangers were the 1990 2.0 Rangers.
The last of the duraspark 2.3's were the early 1985's, because mid year 1985 wth the switch to EFI the 2.3 used the TFI ignition system.
there were NO single plug 2.3 RANGERS after the beginning of the 1989 production run
However the 1989's and early 1990's didn't have Mass Air.,
There were a few EDIS 2.3 single plug 2.3's made, but NONe were installed in Rangers
These were basically the early type EFI lima engine but with 1989-up electronics on them and all were installed in mustangs.
THIS is the ignition system to use on a 2.3turbo if you want EDIS but lack imagination. look for a 1990 Mustang with a goofy looking exhaust side coil pack, it s a coil pack but the towers are moulded shut and there is a resistor inside, this was to "fool" the DPIS ignition system into thinking the second set of spark plugs were actually there on an engine that had no place to put them.
If you DO NOT lack imagination or electrical expertise the ignition system to use on a 2.3 turbo engine is the EDIS4 system used on the second generation (1991-97) Escorts.
AD
AD
