- Aug 6, 2007
- Age
- 50
- Berrien Springs, MI
- State - Country
- MI - USA
- My credo
- If you can't go through it or around it, then go over it.
Once the clutch is engaged, your flywheel might as well be bolted to the transmission. The clutch only matters when it is slipping.
FYI, BDAB, there is a risk to your approach. The engine won't lubricate properly at idle speed at full throttle. I'd say there is a happy medium somewhere. You have to balance engine risk against clutch risk. I agree that you should get off the clutch as fast as possible, but I think that's a bit too fast. Note that you have the same issue with an automatic transmission -- the fluid will burn up if you "slip" the torque converter excessively under heavy load.
I never said anything about WOT......... but my foot is no where near the gas pedal when I let the clutch out.
