- Dec 11, 2016
- Princeton, KS
- 4.0 V6
- Automatic
Looking to have my 2003 transfer case 4x4 module programmed for tow flat.
But the only operation instructions I can find are for the F150 or the Explorer. This is what I've found that seems to apply. Can anyone verify one way or the other?
TO SHIFT THE TRANSFER CASE INTO NEUTRAL FOR TOWING:
- Securely attach vehicle to towing vehicle
- Start the engine to make sure battery is properly charged.
- Make sure the vehicle is at a complete stop and shifted into two wheel drive.
- Place the automatic transmission into NEUTRAL.
- Turn the ignition switch to the OFF position, but steering wheel is NOT LOCKED.
- Depress the brake pedal for 5 seconds.
- The neutral light will go through a bulb check, ; then stay on to indicate the transfer case is in neutral.
- Leave the ignition switch off but steering not locked and transmission shifter in NEUTRAL while vehicle is in tow.
