Torsion Bar Qestion
kamps989
⭐Supporting Member
St. Paul, Minnesota
I was wondering what would happen if I had one torsion bar tighter than the (other than the fact one side would be higher)? Any idears would be appreciated!
Strange handling most likely, and it may pull to one side.
Would this be so even if the truck is sitting level with one tighter than the other? (right now my front end leans)
I wouldn't think so, unless you have a problem in the rear causing it to lean (broken leaf, etc.).
The adjusters won't necessarily be screwed in the same amount of turns on both sides, you just want the truck to sit level.
sweet thanks alot I am planing to adjust them this Saturday, appreciate the help!!
