Toe and camber issues
Why spend the money? All you need is a drop pitman arm and an alignment. I have the drop pitman arm that came with the skyjacker kit. (not the extreme drop one) They were able to get the alignment right and the tires are wearing fine. It does have some bumpsteer but its liveable. The only problem i see with that lift is it uses a drop plate for the passenger side axle beam that can punch a hole in the diff if you don't clearance it. I believe their is a write up on it in the tech library.
So if the majority of you guys think the cheaper drop pitman will make it liveable, i'm gonna go with that. I just wanted to get as much input before I started throwing money at this truck.
At 4" lift it may be livable with the cheaper drop arm (FA400, etc.). If you decide to keep those coils though, then all bets are off.
