Todays weather
It's hot right now
It's been beautiful here all last week.
It's cool enough in the morning and evening to wear a flannel. Don't think the highs made it over 80 and the humidity moved out.
It's been the same here. It's supposed to be around 80 tomorrow and the next day. I really need to scrub the seats in the 2019. So, tomorrow will probably be a good day for that.
Low 60s at night around here, high 70s or maybe 80 during the daytime, pure sunshine and clear skies predicted for the following 10 days, moderate humidity.
The seats did indeed get cleaned. I also spent more money than I should have at Harbor Freight.
This morning the low was a very warm 66. Well, that's a warm low for here. It was cloudy with a little bit of rain, thunder, and lightening. The thunderstorms rapidly dissipated which resulted in downdrafts that knocked over trees, damaged sheds, and scared the squirrels. One downdraft in the foothills descended down slope and warmed as it moved downhill this morning and blew out the cool air out from the nocturnal inversion out of a foothill valley and raised the temperature from 68 to 84 in about 15 minutes. After the clouds cleared it eventually reached 99 this afternoon. It is forecast to cool down to the upper 80s later in the week.
Wha?!?
In a few days, the expected high is going to be around 66. It's suddenly been kind of cool for this time of year, but 66 is not a normal high this early.
It reached 100 today. At 9:00 PM it is a very warm 85. The low tomorrow morning is going to be around 66, which is 10 degrees above what it should be due to a low pulling up tropical moisture. The clouds will keep the temperatures around 85 tomorrow afternoon, then rain tomorrow night and some humidity over the weekend.
It was 70 this morning with 84% humidity. It reached 80 today with humidity wandering between 50 to 75% It will drop down to 63 in the morning with humidity close to 90%, then it will be 88 degrees tomorrow afternoon with humidity around 40%. The humidity will decrease the rest of the weekend until Wednesday when moisture from a tropical depressions is guided north by the high over Mexico. And, there is another one forecast to form off the coast of Acapulco. At this time the moisture from that one is forecast to move north along the west coast of Mexico, then curve inland toward Arizona.
We got some badly needed rain this evening. It hasn't rained in about three weeks and being that it hasn't been a heavy rain, it should soak into the ground pretty well instead of just running off. It will be interesting to see how much of the yard springs back since most of it it has turned brown.
The unusually high humdity finally went back down to normal. The dewpoints are now in the low 50s instead of the mid-60s. I had a problem with mosquitos for about two weeks. Yesterday I noticed that the condensation from the air conditioner was running over the top of the roof and standing in the rain gutter which was partially blocked with leaves creating a pool of water in the gutter, and in an empty planter that happened to roll under the downspout and fill with water. Both had skeeter larvae squirming around in them. It didn't take long to build up a population of them. Mosquito swarms are not something we typically have a problem with in the summer unless you are near the river.
Anyway, it was 92 today, it will be 58 in the morning, then cool down to the 70s by early next week.
Yeah first snow here as well. Not a lot, hardly an inch. Glad I got all the leaves to the street yesterday while it was raining, aint no way i'd have it done today.
