Tires and Rims
belovedb2
My B2 needs new tires and I have decided to also get new rims. I plan to keep it stock. I have done research on our web site and found some rims that I think will fit so I think I am go to go. Here is the plan.
Tires 235/75-15.
Rim: 15X8, Bolt pattern 5X4.5, Off-set -19, Rear Spacing 3.75
Center bore 3.27
The only concern is the off-set and rear spacing. Don't want anything to rub so I am running this by the B2 experts. Am I good to go?
B2 is an 86, not sure that matters
If you are going to run only 235's I would look for a 6 or 7 inch wheel, save you a little cash. The bolt pattern and backspace are ok.
I have 235/75-R15's on my 84 B2 right now on stock bronco 2 wheels that are the 7" wide style, they work just fine other than none of the wheels match LOL.
The rim that I am looking at comes only in 15X8. It's a Rock yuma type. Still OK?
8" should be fine, need to ask bill about haw much clearance is in his front wheel well when he turns his wheels
That be wild Bill?
yah since he ran a similar size tire, ask him how much room was around the tire when he ran it and when he turned the front wheels, i know the tire stores in taxes give you a one month trial of the tire and you can return it within that month if you don't like it or it rubs to much
