they're essentially 30's though, so 2" lift in front and 4.10 gears are good for it then?
yeah, they're pretty limited, I've heard of 235 75 15's fitting on a stock second gen 4x2 with stock wheels (I've seen it too, didn't rub but was TIGHT), with some small lift parts (spacers in front or leveling coils or something) you could probably fit 31's, 2" lift would get you the same height as a stock 4x4, explorer coils would get you there...
with 3.45's, first gear is going to take more clutch work than stock but should be doable with 28" tires or thereabouts, with 31's you are going to want at least 4.10's preferedly 4.56 gears.
just reread a couple posts and I misunderstood someone talking about needing gears when I thought they were talking about tire fitment... so oops...
Now if your truck had factory 17 inch wheels then dont go any smaller because it wont clear the calipers.
Those tires and those gears are going to be a dog. I didn't answer the question about those tires fitting. I've had zero experience with 2nd gen's.
that's what I realized after my first post...
I know how it is a dog... I ran 28" tires with 3.08 gears for a while... other than starting from a stop it wasn't bad, didn't have the engine rpm's to use 5th gear but 65mph in 4th was the perfect rpm
