tire help
steelheadboy
snohomish,wa
how bad will 32/11.5 pro comp M/ts rub on a stock 96 ranger extended cab 4.0 4x4?
it depends alot on the wheels, are they stock? if not do you know the width and offset?
not exactly sure where but you will rub, my guess is on the radius arm and the inside of the fender at full lock. you might be able to get away with a leveling kit and a slightly lower offset (-6 to -19ish) 15x8 wheel.
They will probably rub alot. I'm running that size 2"TT and 2"Shackles and I get rub on the front sway bar and the rear wheel flare.
