- May 17, 2010
- Age
- 47
- Manual
If it makes you feel better. My 2.3L engine has the same problem. After lining up all the marks, the timing belt would be a half a tooth off on the cam. The first 2 times when I aligned the marks, I retarded the crank a half tooth. This last time around, I advanced the crank a half tooth. Either way, no problems. It doesn't really matter too much with this engine, as long as you got it as close as possible.
Well if a Rocket Scientist says it's no big deal then yes, it does make me feel much better
For records sake; I retarded the cam pulley by half a tooth because I assumed as the belt wears in and gives a little that would advance the pulley on its own, thus making it all perfect (in theory anyway).
