ticking noise on 700 mile fresh rebuild
Cherry Valley
CA - USA
Vehicle
Drive
i have a 2000 ford ranger xlt 4.0 v6 4x4 i did a fresh rebuild about 700 miles ago it has new everything except the following, block, pushrods and the rocker arm assy, plenum, injectors. The ticking noise will start on a cold start and it sounds very loud, it goes faster with rpms, sounds like a sewing machine, it only goes away after it goes to half temp then it runs and drives and sounds amazing. used a mechanics stethoscope on everything sounds the exact same which leads me to believe its in the middle of the block. if there is anything you guys need to know please ask, i really need your guys' help and opinion on this.
Sounds like a lifter sticking. I would say put a can of Rislone in it to unstick the lifter, but that is for older dirty engines, yours is new and should be clean. If you are worried about it, you will need to track down the offending lifter and replace it. New parts quality has been very bad the past few years.
