TIB drift Rangers?
JoshT
⭐Supporting Member
Macon/Fort Valley, GA
GA - USA
Vehicle
5.0L
few inches
~30"
I'm sure that there are a few people around here that like to throw their Ranger sideways and turn tires into smoke. Any of you do it with a TIB Ranger?
I've thought for many years that a cheap dirty drift vehicle would be fun and, being me, a first gen Ranger is the only acceptable choice. In the yard I've got a gutted 86 Ranger regular cab short bed. Well it's beyond gutted, the bare frame is in one spot, the stripped out cab is in another, and the bed is in a third. I'm considering throwing that 86 back together over the winter to thrash at a local track that hosts a small monthly drift event. Already got the add lightness part of building a race car covered, I just need to put back whats necessary which won't be a problem.
Biggest issue is I'm not sure what parts to pick to put on it. I know that the TIB is less than ideal, but that's what it is going to be for now. Later if I really get into and stick with it, I'll be willing to buy/fabricate custom front and rear suspension, cage, etc. Initial setup is going to be on the cheap. Primarily composed of parts I alredy have or can get relatively easily at the salvage yard. Not concerned with powertrain at the moment, have a few options, but need/want to get it rolling before driving matters. Suspension, I'm really not sure which direction to go.
For fronmt suspension... I have at my disposal and can put towards this project, a full stock first gen suyspension and brakes. I have a set of first gen dream beams and I think a set of drop springs. I have a 1-1/8 to 1-1/4 aftermarket first gen ranger anti-sway bar. I also have a set of brackets for running the 12" ST rotors on 95-97 steering knuckles, but those won't work with the first gen parts. As I see it I have two options for assembling a front suspension on the cheap.
1) Dream Beams, drop springs, antisway bar. That'l get COG down with the ~5" drop and help get rid of body roll. Add a set of 16-18" wheels from market place and wrap them with a with fairly low profile tire. Brakes are kind of anemic, but not sure if that matters on a drift car.
2) Set of stock 95-97 beams & knuckles from salvage yard, good luck finding Dream Beams there these days. Drop springs. ST brakes. Anti-sway bar. Again add in the wheels and tires. The spring will still drop COG some, the antisway bar wil help with body roll. Much better braking IMO. The lowering will induce more negative camber with the stock beams, but that might actually be favorable for a drift car.
For those of you with the experience, which would you do? What kind of alignment specs (camber, caster, toe) would you shoot for? How would you go about getting more steering angle on these suspensions?
I've got to see what I want to do for rear axle. Might have to spend a little money there. I have got an Explorer axle available, and it would be the easy button for rear discs, but not sure I want to use it for this. Might have to stay with a Ranger axle and weld the center section. I would convert the Ranger axle to discs, actually I'd probably build it for a dual caliper setup on the rear with the handbrake having its own caliper. Of course a set of anti-wrap bars. Have a 1" BII anti-sway bar I can put on. Can rebuild some leaf packs with more springs to be extra stiff if that would help anything.
FWIW this does not need to be road worthy or street legal, unlikely to ever be tagged or insured. Would be trailered to and from the events. Stuff that I wouldn't consider driving down the road is acceptable and possibly even favorable for this. This is a completely separate project from what the 85 is going to be, and I've got the gooder parts earmarked for it.
calling matt.........turbo 5.0 tire converter
Someone a while ago was working on something like that and they wanted to increase the steering response and shortened the links on the spindles, it would make WAY more sense to lengthen the pitman arm...
I'm for it, I don't have anything that will even do a burnout let alone drift predictably so I don't have much to add...
'90 converted to 4x4, turbo'd the 2.3, 6" lift with 35's and 5.13 gears!
'97 4x2 extended cab 2.3L commuter beater
'98 and '00 V8 Explorers, one to be soon(ish) project... '00 has mild cam, headers and 4x4 conversion
'97 F350 4x4 CCLB 7.3 manual beat up tow pig, it complains alot anymore...
I can't believe NONE of those can spin the tires. I did fine with a stock 92 2.3 manual 2wd. Maybe you have to much tire on them all. LOL
Ok, they can but it REALLY depends on what's happening at the time... annoyingly on the '90 the rear brakes overpower the engine (possibly user error), same with the '00 Explorer (when the rear brakes went out it was no problem doing burnouts lol). On wet roads the two '97's will go for it but the axle wrap on the F350 is bad enough I dare not try...
In short I haven't really tried all that hard, having a way to bypass the rear brakes would help a LOT
Brakes are easy to bypass.... especially with the 4rabs
It was easier to use brake bias than blow front shafts...though I did start to kill spiders...
ok, you have me intrigued... I've been contemplating ways of keeping the 4WABS on the '00 Explorer with my planned axle shenanigans' for no great reason other than it's there? I have too many parts to not do this soon... I've thought about looking into line locks or a valve to just block off the rear brakes for "reasons" but I've just never been all that into burnouts, not even enough to just take vise grips to the rear soft line like most people do...
Burnouts are fine, but I would rather be making tire smoke from sliding around corners than in a burnout pit. Making the tires smoke isn't really an issue, but the way to do it seem to be a little different for drift than for burnout comps.
Burnout comps the line lock or vice grips to disable rear brake works, then stand on the front brakes and boil them. That ain't going to work for drift, but you definitely still want the brakes to be fully functional.
