CraigK
- Nov 17, 2007
- Automatic
By Bronco II suddenly started listing to starboard, and the wheels don't look aligned properly. Cursory inspection shows that my front passenger side coil spring mount bracket has broken in half! The coil spring itself looks like it has shifted and is bulging outward.
What needs to be done to fix this? Is this bracket welded on? Bolted on? What special tools would be required to get the coil and bracket off and on? What other part will be affected and/or needed? Where might replacement brackets be available? Is there any aftermarket brackets that might be better than the Ford part?
As usual, any help would be appreciated! Thanks.
CraigK
CraigK
