The Dually Ranger
That's a nice-looking Ford Ranger, BlueRanger123. Is that yours?
Yep, that's mine. ;) I got laid off my job a week ago, but I have an interview for another job tomorrow. If I make enough greenies, I was thinking about swapping the rear tires for ones with a more coarse tread pattern. Same height, and maybe a bit wider.
I found a set of Dually hub adapters at a U pull it on a 89 ranger. The rims are junk, 15 inch. Studs are 5/8. Anyone know what the pattern is?
Should still be 5x4.5 unless someone swapped the axle. Might be a Toyota axle. You should be able to tell.
Are these the long spacers that kind of look like a 10 inch long wheel adapter? Where the outside wheel is bolted through them with long bolts?
Do the look like this?
The Dually Ranger
The Dually Ranger
What are they asking? If you don’t want them, could we work something out for you to get them and send them to me in Atlanta? My interest would only be if they’re standard 5x4.5. Probably need pictures. Happy to send you a few bucks to go back and look. More pictures always better
Dually Rangers??? 😃😆 For extra weight, right? Like if the owner wants to add a window unit ac to the rear slider to keep his mullet cool? ...”2 wheels, just ain’t enough!”
