- Apr 1, 2015
- Automatic
My engine has a slight miss somewhere during idle. Could be allot of things ofcoarse but, one of the things I would like to make sure of is that the plug wires are actually connected to the sparks plugs. Some of the boots do not ‘click’ onto the plug but ‘seem’ to be connected/jammed on as far as possible.
With a spark plug wire attached to the spark plug, is there a way to test to see if it is actually connected? I’m not trying to check for spark by removing and grounding the plug, but rather, I’m just wanting to test whether the plug wire is properly connected to the spark plug, with the plug and wire in place.
Perhaps, without the engine running, I could disconnect a plug wire from the distributor (which, unlike the plug boot, is much easier to check the connection) and connect an ohm meter or test light to it and to the engine block to check for continuity? Thanks
