tensioner Assembly question
booblinker
Richmond twp, mi
I need to replace my tensioner assembly because it is seized and the bearing in the pulley is bad. What tool do i need to get the bolt out, looked like it might be torx? I have a 93 ranger 3.0 with a/c
Theres only a torx bolt holding the tensioner in and a pin that lines it up. First take the belt off. Then take the bolt out. Once done then you can just slide the tensioner off. Also I think there was washers on both sides of the tensioner but I cant really remember. Just take precaution and make sure to take note of how any washers go.
