- Nov 22, 2013
- Manual
Howdy all,
I used the search function and could not find an answer, so figured that a question here might be tolerated.
I just replaced the thermostat and gauge temp sensor, got most of the air out of the top hose, took it for a test drive, and noticed that the needle does not get above the bottom line of the arc on the gauge.
This is a 95 Ranger 4X4, 3.0 engine.The reason for the replacement was because I thought the thermostat was broken, since the gauge didn't go up.
The question is, where should the needle be when the temp is 195 deg at the thermostat housing, as measured with an infra red non contact thermometer?
And does the ECM use that reading to control mixture? I have noticed a decrease in mileage the last half year. This has an OBD1 system.
Thanks for any input.
CZ
CZ
