Tachometer showing wrong RPM
Nez'sRanger
5+ Year Member
Pennsylvania
My 89 2.9 has this strange problem with the tachometer. When I first start it, usually when cold, the tach will give me a reading nearly 2,000 higher than it really is. It usually normalizes later on, but it's pretty annoying. Any idea what's up?
I'm having EXACTLY the same issue. Not finding any info...
Tach signal comes from a splice in the Coil "-" wire, between TFI and coil, a tan/yellow wire(or dark green/yellow)
If the engine is running OK then that signal is OK
The splice runs to the Computer(pin 4) and to the cluster, both tan/yellow wires(or dark green/yellow)
Don't know where the splice is, but the tan/yellow(or dark green/yellow) wire from TFI to Coil is not that long so it may be at the TFI connector or coil "-" connector
The Computers tach signal has an inline resistor
Computer would set a 2 digit code if Tach signal was erratic, like:
18 (R) Check base timing & advance function – Timing Tests
.........(M) Ignition TACH signal erratic – Ignition Systems
Tach also needs a good ground at the cluster, loose or intermittent ground would cause the high low RPM on Tach
Its a separate ground for Tach only on the cluster
If there has been no codes or engine running issues related to spark timing then problem is most likely at or in the cluster
Watch yard/garage sales for timing lights and hand held Tach/RPM meters, good to test signal at the cluster, and of course in engine bay
@ RonD:
A little off the subject I know but could I install an extra tach under my hood without any issues ?
Thanks !
@ RonD:
Thanks !
RonD hasn’t been on here for over a year and when he left he said he was going to be gone for good.
It is possible to tap into the tach signal wire under the hood or under the dash. Both my first Ranger and my F-150 I tapped into the tach signal wire under the dash.
Thanks, didn't know that.
I'd like to put a tach under the hood without any issues (TFI, EEC or whatever) & I do have the factory dash tach.
I just want to be sure it's safe.
I know where to hook up one for under the hood.
Thanks !
