T5 into 96 4cyl ranger??
stackz
I tried searching but T5 is too short a term and the tech articles only mention it for v6 trucks...
truck is bone stock and the tranny took a dump. havent had any luck finding one and I do have 5 4cyl mustang T5's as well as a bellhousing/fork setup and flywheel/clutch setup I could use.
even have a driveshaft yolk too.
aside from maybe having a different shifter position on the floor and possibly backup sensor problems...what else would be bad with trying to do this to get the truck back on the road cheaply??
are your trans's hydrolic or cable. i think most of the mustangs are cable and your truck is hydrolic. i think the length on the trans is different also. i haven't done this swap so im not 100%
im sure someone would swap you a stock trans for a t5 if it ends up being alot of work to do.
good luck
tbird
I thought the thunderbird turbo coupe T5's were hydraulic... would be a good time to get all the turbo stuff as well off the car..
I have an '84 turbo coupe t5. It is cable.
They do make aftermarket slave cylinders for t5s so it is possible. I think that it would be more trouble and expense then it would be worth though. The M5OD R1 is a good trans, It can easily handle the torque of the 4cyl, there is a hurst shifter available for it, and it bolts in.
The T5's shift soooo much better is not even funny.. The M5's have taken a beating and came stock so easy to work with them. I have a girling(spelling) slave cylinder,a some steel plate/angles, and a rod actuating my mustang t5 in my 5.0 ranger.. so it can be done.. Found a SS braid hose with adapter instead of the plastic stock line. I don't remember part numbers but I could take some pictures of the setup if you want me too.. it looks a bit rough, but I did it quick cheap and dirty.. has worked well cept the exhaust was close before I put the turbos on. It burn up a seal in the slave once or twice in the summer.. its rebuildable tho
Anyone with a 87-88 manual turbo coupe able to chime in.. my auto tbird coupe should sell off craigslist tonight hopefully. I know the cable pulls can be converted with a plate, rod, and slave cylinder.
i believe it was the 87-88 turbocoupes that used a hydraulic clutch with the T5, so you could grab a bellhousing from one of those and have no problems.
ok, so aside from getting the hydro bell from a TC, the swap would be pretty much straight forward?? no cutting a new hole in the floorpan for the shifter??
is the lengths on the trannys similar enough that the stock crossmember and driveshaft can be used as well??
it just seems people get to the ranger transmissions a LOT quicker at the u-pull the mustang T5's is all and I've already got most of the parts.
oh yeah, why couldnt I just use the cable pull bell and remove the hydraulic clutch parts and run a cable up to the firewall and just either swap the clutch pedal or modify it to work with the cable??
I had to do this in the past on a civic that I swapped in an early integra drivetrain....the civic was setup as hydraulic slave cylinder but the integra was cable clutch so I just cut/welded to the two clutch pedals together and drilled a hole in the firewall for the clutch cable. it worked fine for 2 years before the car rotted apart haha.
The t5 is 1" longer, the driveshaft may work just fine. At least it is cheaper and easier to cut down a drive shaft then it is to lengthen one. The shifter is 9" farther back. A new hole is definatly required and the shifter is going to be in a bad location. With buckets and a custom handle it would be fine.
If you were somewhere close to me I would give you a M5OD for a good deal on a WC T5.
hello Guys im new here and i am in the process of swaping my ranger to an Svo 2.3 turbo, i already have the engine intalled. but i want to install the t5. has anyone adapted the Cable to work or have a part number for an internal slave that will work fir the t5?
also will the stock crossmember work or will i need to modify?
The thread you replied to is almost 10 years old. Start a new one, and be thorough in your information and questions.
did you ever find a solution to this for your swapz//??
T5 is a easy swap. Need '87-'88 Turbocoupe bell housing & slave cylinder, 10 spline clutch, custom clutch line ('91 & older trucks can use clutch line from an '83-'84 4cyl manual ranger as a plug & play setup, idk if it works for the later clutch master cylinders), cut hole in floor or convert to forward mount shifter (S10 or Modern Driveline tail housing), & relocate the transmission crossmember forward. transmissions are close enough, if not the same length that you can use your stock driveshaft without a problem. The transmission yoke is even the same spline. This is all 1st hand experience as I have installed T5 in my '91 2wd 2.3t truck. About to do this swap again in the coming months to my '88 GT.
