T5 crossmember
Yes, stock t5 mount fits perfect. To be specific, mine is from a foxbody . Im not sure if the sn95 is different
Sn95 is suppose to have a longer input shaft.
Good to know.i was contemplating getting that crossmember for mine.now maybe I might.thanx for info
I wonder if frames are similar on yours to my 1st gen
Yall have to get a different driveshaft for t5?
Is it to long or to short?
I have a sn95 as parts car that has t5 In it already.hoping that your fit right in.if not best case scenario it's to long and I need it shortened.fingas crossed.
Ricks rangers crossmember bolted to a t5
When u have it mounted up to crossmember does your shifter mount seem to lean to the driverside or does it sit perfectly flat and even with your floor?
Does your shifter seem to lean towards the driverside or does it sit level with your floor board?
That's exactly what I mean.thank u for the quick response
