30coupe
I also found this:
http://www.trustmymechanic.com/motor-oil-bible.pdf
As near as I can determine, this guy has no connection to AMSOIL. It is part of this website: http://www.trustmymechanic.com/motoroil.html
I did a google search for best motor oil and this is one of the sites that came up. I am not trying to justify Amsoil, but your posts got me wondering about it. The Motor Oil Bible is pretty long and technical, but toward the end it has comparisons of many motor oils. Amsoil ranked at or near the top for each weight of oil, so I guess I will continue to use it. With the extended drain interval, it is actually cheaper than even dino oil. The bible guy also explains the API license thing. Amsoil is not the only one that doesn't have the API license, apparently several premium oils do not carry it, for much the same reason as Amsoil.
The bottom line is, synthetics are generally better than dino oil, but it pays to do your research. I did, so I am sticking with Amsoil.
