sway bar help
ZenXtra07
Hey guys. I have a 96 ranger 2.3 w/o a rear sway bar. It's in the shop right now and I don't know if the sway bar I yoinked at the yard will fit on it. The sway bar is of the rear end of an 89 Bronco II. Normally I'd just bolt it up, but seeing that I'm gettin 4.10's and an l/s in right now, I don't much have that option.
Thanks alot!
Also, I need to know if my ranger (xlt) has 4 wheel ABS.
I think your truck should have all wheel ABS. And as for the Rear sway bar you should not have any problems with it fitting. However you may need to do some minor mods to get it to fit.
My 96 "WAS" Rear ABS only. I never liked it much and with the current rearend missing the tone ring, I have a regualr set up. I've only lock it up once and that was trying to.
James
