Swapping 95 ranger 4.0 with 86 bronco 2 2.9
Rocky Gap
VA - USA
Vehicle
Ford Bronco II
Drive
2.9 V6
I need a wiring diagram for this
Can you make the title more clear? It sounds like you are putting a 86 2.9 into a 95 ranger that had a 4.0. That is a rare occurrence if you are.
A 95 is going to have OBD II and you are going to have to swap the entire electrical system because nothing will match most likely.
Putting the 95 4.0 ranger motor in the 2.9 bronco 2. I was just trying to find the diagram for this. I didn't realize I had to switch everything til after I started
Here is some reading for you.
