suspension noise
mwood1985
Marietta GA
ok after wheeling in north ga and driving up a 2 foot roadside into the woods i have a bad squeal whenever i turn left in my 2001 4x4 but it seems like its coming from the right side of the truck. it also has the same sound when i hit bumps on the road. i replaced the shocks today and made sure the nuts and bolts were tight throughout the control arms torsion bars sway bars ect. im thinking i might have damaged the sway bars? anybody got any ideas on how to find and fix this
Need to narrow it down..
Only does it when turning?
Sound like metal on metal? Rubber on Metal? etc
it does it most noticably when im turning left and there is some suspension noise when i hit bumps on the road. high speed not a sound its a low speed thing ie under 45. it sounds like metal on metal but im not really sure
Is it constant?
If so, i would check your brakes, bearings, dust shields and stuff like that.
ok
its a steady intermittant squeal if that makes sense. everything brakes dust shields ect. looks ok but how do i check the wheel bearings?
