Suspension Lift
And the super lift suggests not using the super runner steering kit with lifts over 6 inches...and I will have 7 (3Bl and 4SL)
QUOTE]no,superlift is referring to suspension lift when they give the 6" restiction,which you will only have 4"s of.you will still need to correct the steering or have bad bumpsteer.the lift manufacturers and most wheelers will tell you not to go over a 6" suspension anyway because its real hard to put steering geometry back in spec.
OH ha ha I was wondering that...but is this system really worth the extra $350?
i don't know but a drop pitman arm puts more twisting force on the frame rail and doesn't work as well.i'm getting the kit when i get the chance.
You're getting the SuperLift kit? Which one exactly? and from where?
So if I can find a 98 and up ranger super cab front driveshaft...it will be a direct replacement? That sounds easy enough! I've never heard of that shop but will have to check them out. I'm kinda near the Franklin Park Mall area....little bit northeast of it...how about you?
Thanks for the welcome and info.
diversified is at the corner of mccord and angola, its behind the strip mall there. btw, i live in swanton, work in point place, and have family within a mile of the mall...
