searched and did not find. anyone have any suggestions hardwiring a multi-port DC12V outlet? I would like for it to only come on with the ignition. 94 Ranger
Use a relay. Use the same wire size thru a fuse that is currently on the port for power, then connect the relay coil to a switched circuit with a smaller gauge wire.shady
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
