Stuck lug nut
My trick is to have a friend pull out on the tire where the stud is and pull hard so that its tight against the lug nut and use the gun to get it off. Hasn't failed yet.
if this doesn't work then you can pull up or down with the socket as you rap the gun.
you'll probably need a new hub by the end up this.. but you might get lucky and only the stud got stripped out
yeah umm yall got lucky with it haha. someone tried to steel my tires while i was livin at the beach last summer after graduation. they knocked four of the studs loose on the passenger side front tire. i didnt have any tools, the only welder on the island wouldnt touch it and none of the mechanics would hit it either, so i spent 3 days with a chisel and hammer splitting the lugnuts in half so i could pry the lugnuts off of the stud... ended up with a new rotor, a pack of lugnuts, and wheel berings while i was at it. :annoyed:
got it all fixed though and wheeled on the beach for the rest of the month. :)
i wouldnt suggest doing it this way, but when all else fails. just remember, it could be worse haha:icon_cheers:
Oh em Gee!! This has been a long day thanks for all your guy's help seriously! I ended up torching them off. Yep them as in two, two lug nuts were stuck on there like a son of a gun!! Really thanks for all your input guys!
