Stripped Nut..
hell, while your at it, remove the door thats in the way, centerpunch the head of the screw and drill the head off. start with a 1/8" drill bit and move up to about a 1/4" bit. the head will pop off when you start drilling into the shank of the screw. then you will just have to get a set of vicegrips and remove the shank of the screw from the insert when the fender is off.
And then throw a bundle of dynamite into the cab and send whatever is left to the scrapper. I just got $10 per 100# a couple weeks ago.
another thing that will help later is to use 6 point sockets on stubborn bolts,they won't strip as easy.
did i miss something? why the hell are you tearing your truck all the way apart?
x2 ???????
:icon_confused: I understand that six point sockets are less likely to round off the head of the bolts, but less likely for them to strip?
How does that work? :icon_confused:
of course i ment the head of the bolt;missingteeth;
tell us boggin, are you strippin it down to make a tube buggy crawler?:icon_twisted:
