- Sep 6, 2009
- Automatic
Awhile back I posted about my carpet in the front seat area getting wet under the rubber mats and smelling like cat piss. Well it was nothing but rain this week and I noticed that the carpet was really really wet and smelled horrible so I decided it was time to look into fixin this. So I took everything out of the inside and pulled the carpet out. Cleaned the whole tub out with a vacuum and got out the garden hose. Turns out water was trickling down from the pedal area and beside the computer. So I opened the cowl compartment and found a bunch of mouse junk in it and big chunks of gray seam sealer stuff. Cleaning out the cowl took care of the drivers side leakage but there is still a small trickle by the computer. It comes right down the gray wire loom. Also, there was a bag of fiberglass insulation and some foam rubber sheets stuffed up in the fenders, so I pulled this all out, in hopes it will let water drain better instead of backing up into the cab.
I hope the pictures are okay size
Any input on this?
Any input on this?
