Strange fuel problem
TillamookB2
15+ Year Member
Portland, Oregon
I was driving the other day. The bronco just shut off. Like I had turned the key off. Except I didn't.
We noticed the pump in the tank was not working. So, I replaced it with the sending unit and everything. Doesn't work.
We have power at the fuse. We also checked the relay, which appears to be in working order (we took it off and applied power and it clicked.) We can put a wire across the piece that plugs into the relay and both pumps click on. We can hear fuel in the lines that run up to the motor.
We have sprayed a bit of gas into the intake and it will run, but only until that fuel is burned up. I don't have any idea what the problem could be. Any ideas?
I take it your from Tillamook .........
I grew up there..........
Hey I live in Tillamook. I'm sure I've seen your B2 around.
you know a Monte Derrick?
Probably have seen me around. I just put a pic of my b2 in my profile. Its the silver one with the jolly roger on it.
The ground for the fuel pump relay was burned. How it happened, I don't know. But, its fixed and back on the road. And with a new fuel pump and sending unit. Too bad I don't have enough money to find out how well the sending unit works.... Gas is at $4.39.
