jfl1960
Other than the 63mm in the HO intake vs 52ish mm opening in the stocker are there any other differences in the upper intakes, I know the lowers are the same, I have two of the stock intakes (UPPER AND LOWER) and one HO TB at 63mm with correct egr spacer for HO setup, would it be possible to just port one of the stock intakes to the 63mm size I need and get any decent results, I have read many articles on porting the upper and reducing the restriction through the bolt boss locations, but this was only on the HO intake in the article I found, bear in mind this is a 86 5.0L from a crown vic, really limited in what I can do cam and heads wise, got an HO cam and the E7 heads but cannot afford the pistons just yet to use these items. I figured make it breathe a bit better and use a mild cam for now, any comments are appreciated.
