- Aug 19, 2007
- Age
- 40
- Manual
Ok, so I have the normal high idle issue, and to make this short, I thought I found the fix by swapping the plenum intake for reasons that didnt help anyways. Well I found that the vaccum line going into the throttle body, where the butterfly valve is, the line was broken. This line goes into the charcoal canister. Anyways, I figured that was causing the high idle, so i spliced it with a new line and made sure it was nice and tight. Changed the pcv valve and connection with a new rubber tube, made sure it was tight and didnt leak. I cleaned the air charge temp sensor and the vaccum tree, put it all back together thinking problem was solved. NOT. The dam thing would not run on its own, I'm not sure why this was but after so long, finally it would stay idling on its own, but it fluctuated back and forth for a while then FINALLY it stayed at a steady idle but, it had a really bad miss. So i figured i would drive it around for a couple miles, running it decently hard to run the bugs outta it and every time i would shift, there it was, the high idle, but its worse. How can I clean everything, replace the gasket, make sure everything is tight, and its now worse? Could I have the vaccum lines mixed up on the tree? I figured as long as the lines were getting vaccum it didnt matter where they went, but maybe i'm wrong. What else can I do now? How could it be fine before and now change it and it become worse?
