- Feb 17, 2018
- 2.9 V6
- Manual
I have a 1987 Ranger STX 2.9l 4x4 manual transmission. I have just replaced the starter motor which had failed. The engine now starts, but the battery drains overnight with all electrical accessories off. The problem appears to be a grounded wire on the feed terminal of the starter relay. There are five wires connected to the feed terminal including the +battery cable. the other four are colored red, orange, yellow and black. There is continuity to the chassis from the black wire. The black wire is in the harness that includes the R/LB clutch interlock switch wire. It is larger in diameter than the clutch interlock switch wire. It is the wire leading straight down in the attached picture of the wires and relay. Is this an ignition switch lead that may be grounded? The starter motor will not run without it. The rubber connector has "FUSIBLE LINK GA" stamped on it. Thanks for any help.
