⭐Supporting Member
- Sep 20, 2009
- Dillsburg PA
- 4.0 V6
- Manual
- Tire Size
- 31X10.50X15
@adsm08 By starter alignment plate do you mean the large one bolted between the engine and the trans?
Yes.
You should be able to remove all the bolts, except the two at the dowel pins (along the horizontal center line of the trans) which can be backed out about two turns, and slip the plate out for inspection.
